I went to install a new mod that allowed inline video, but it did't go too well (Will try again later).
But I have installed some new codes....
For this you need to find the ID number from the video.
If you look at the URL:
you need the bit after "?v=" and before the "&". In this case qUR25oPce5k
For example.
Code: Select all
http://www.youtube.com/watch?v=qUR25oPce5k&list=UUpe9GzihiKb8sFaDU8qaguQ&index=1&feature=plcpFor example.
Code: Select all
[youtube]qUR25oPce5k[/youtube]Ben
This one is particularly cool!
To embed a map, first go to google maps and find what you want. Click on the Link icon and copy the link to the clipboard. Then past it in the googlemaps code.
For example:
View Larger Map
For example:
Code: Select all
[googlemaps]https://maps.google.com.au/maps?q=Aratula+QLD&hl=en&sll=-25.335448,135.745076&sspn=59.622642,79.013672&oq=arat&hnear=Aratula+Queensland&t=m&z=14[/googlemaps]View Larger Map
Code: Select all
[important]This is some important test[/important]This is some important test
Code: Select all
[marquee][b]Bouncing text[/b][/marquee]Ben
Code: Select all
[rainbow]I like Rainbow text.[/rainbow]Ben
Code: Select all
[neonlights]Toyota LandCruiser[/neonlights]Ben
You can now also add Vimeo videos inline.
This works similar to the youtube videos as you need to pull out the video ID from the URL.
For example if a video had the following URL:
the ID would be:
So to use this in a post you would:
Code: Select all
http://vimeo.com/55217343Code: Select all
[vimeo]55217343[/vimeo]Ben
